Keysight Technologies N9030B controlled LISN
Jump to: navigation, search
The Keysight Technologies N9030B controlled LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies N9030B controlled LISN:
The frequency range of the Keysight Technologies N9030B controlled LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Keysight Technologies N9030B controlled LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Keysight Technologies N9030B controlled LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
