Laplace 16A1P
The Laplace 16A1P device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Laplace 16A1P:
The frequency range of the Laplace 16A1P as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Laplace 16A1P.
Be careful changing these setting as RadiMation® is no longer able to verify if the Laplace 16A1P is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Laplace 16A1P
- Google image search: Laplace 16A1P
