LeCroy WaveSurfer Channel A
Jump to: navigation, search
The LeCroy WaveSurfer Channel A device driver is a Switch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the LeCroy WaveSurfer Channel A:
On the Channel Selection tab, the desired channel that should be measured can be selected.
ScreenElementDescription.png Channel 1 Channel 1 will be used as the measurement input.
ScreenElementDescription.png Channel 2 Channel 2 will be used as the measurement input.
ScreenElementDescription.png Channel 3 Channel 3 will be used as the measurement input.
ScreenElementDescription.png Channel 4 Channel 4 will be used as the measurement input.
ScreenElementDescription.png Measures The 'Measures' as they can be configured on the LeCroy oscilloscope will be used.
Some LeCroy oscilloscope devices only have 2 input channels, and in that case the configuration dialog will only show the channels that are supported.
Channel
If one of the Channel options is selected, the EUT Monitoring device in RadiMation® will use the following mapping:
Channel Measurement Maximum value
1 Minimum amplitude 353.55 V
2 Maximum amplitude 353.55 V
3 Amplitude 353.55 V
4 Peak to Peak voltage 707.1 V
5 RMS value 250 V
6 Frequency in MHz 200 MHz
7 Dutycycle 100 %
8 Trace dump
The 'Trace dump' mode retrieves the trace data of the selected channel, and then creates a DUMP_<FREQ>MHz_<YEAR>-<MONTH>-<DAY>_<HOUR>-<MINUTE>-<SEC>.CSV file in the C:\Work\ directory that contains the raw data of the complete trace. The graph in RadiMation® thus doesn't show any logical information, however all the raw data of the traces is present in several files in the C:\Work\ directory.
Measures
If the Measures options is selected, the EUT Monitoring device in RadiMation® is retrieving the values from the 'Measure' that are configured in the LeCroy oscilloscope itself. The to be measured value can thus be configured in the LeCroy by using one of the available measurement functions. See the end-user manual of the LeCroy on how these 'Measures' can be configured. The measure configuration in the LeCroy also includes from which input channel the value should be measured. These measures are numbered in the LeCroy, and the same numbering is used in the RadiMation®. The EUT Monitoring channel 2 will thus use the value of Measure 2 in the LeCroy.
