LogiMetrics AN8200G
Jump to: navigation, search
The LogiMetrics AN8200G device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the LogiMetrics AN8200G:
The frequency range of the LogiMetrics AN8200G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the LogiMetrics AN8200G.
Be careful changing these setting as RadiMation® is no longer able to verify if the LogiMetrics AN8200G is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
