Luthi CDN AF-250V
The Luthi CDN AF-250V device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi CDN AF-250V:
The frequency range of the Luthi CDN AF-250V as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Luthi CDN AF-250V.
Be careful changing these setting as RadiMation® is no longer able to verify if the Luthi CDN AF-250V is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Luthi CDN AF-250V
- Google image search: Luthi CDN AF-250V
