Luthi MDS 20
Jump to: navigation, search
The Luthi MDS 20 device driver is a Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi MDS 20:
The frequency range of the Luthi MDS 20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Luthi MDS 20.
Be careful changing these setting as RadiMation® is no longer able to verify if the Luthi MDS 20 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
