Luthi MDS 21B
Jump to: navigation, search
The Luthi MDS 21B device driver is a AntennaAbsorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi MDS 21B:
The frequency range of the Luthi MDS 21B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Luthi MDS 21B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Luthi MDS 21B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
