Manual Controlled Amplifier
Jump to: navigation, search
The Manual Controlled Amplifier device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Manual Controlled Amplifier:
The frequency range of the Manual Controlled Amplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Manual Controlled Amplifier.
Be careful changing these setting as RadiMation® is no longer able to verify if the Manual Controlled Amplifier is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
