Manual Operating LISN
Jump to: navigation, search
The Manual Operating LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Manual Operating LISN:
The frequency range of the Manual Operating LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Manual Operating LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Manual Operating LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
