Marconi 2030 (FM Modulated)
Jump to: navigation, search
The Marconi 2030 (FM Modulated) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Marconi 2030 (FM Modulated):
The frequency range of the Marconi 2030 (FM Modulated) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Marconi 2030 (FM Modulated).
Be careful changing these setting as RadiMation® is no longer able to verify if the Marconi 2030 (FM Modulated) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
