Marconi 2042
The Marconi 2042 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Marconi 2042:
The frequency range of the Marconi 2042 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Marconi 2042.
Be careful changing these setting as RadiMation® is no longer able to verify if the Marconi 2042 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Marconi 2042
- Google image search: Marconi 2042
