Milmega AS0102-30RN
Jump to: navigation, search
The Milmega AS0102-30RN device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0102-30RN:
The frequency range of the Milmega AS0102-30RN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Milmega AS0102-30RN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Milmega AS0102-30RN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
