Milmega AS0104
Jump to: navigation, search
The Milmega AS0104 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0104:
The frequency range of the Milmega AS0104 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Milmega AS0104.
Be careful changing these setting as RadiMation® is no longer able to verify if the Milmega AS0104 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Note: When connecting the amplifier via LAN please use the TCP/IP stream and use port 5025. Where you see the ip-adress 192.01.01.01 use the ip-adress of the amplifier.
