Milmega AS0827-15
Jump to: navigation, search
The Milmega AS0827-15 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0827-15:
The frequency range of the Milmega AS0827-15 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Milmega AS0827-15.
Be careful changing these setting as RadiMation® is no longer able to verify if the Milmega AS0827-15 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
