Milmega AS0840 (remote low band)
The Milmega AS0840 (remote low band) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0840 (remote low band):
The frequency range of the Milmega AS0840 (remote low band) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Milmega AS0840 (remote low band).
Be careful changing these setting as RadiMation® is no longer able to verify if the Milmega AS0840 (remote low band) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Milmega AS0840 (remote low band)
- Google image search: Milmega AS0840 (remote low band)
