Mini-Circuits SSG-6001RC
The Mini-Circuits SSG-6001RC device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Mini-Circuits SSG-6001RC:
The frequency range of the Mini-Circuits SSG-6001RC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Mini-Circuits SSG-6001RC.
Be careful changing these setting as RadiMation® is no longer able to verify if the Mini-Circuits SSG-6001RC is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Mini-Circuits SSG-6001RC
- Google image search: Mini-Circuits SSG-6001RC
