Mini-Circuits TIA-1000-1R8
Jump to: navigation, search
The Mini-Circuits TIA-1000-1R8 device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Mini-Circuits TIA-1000-1R8:
The frequency range of the Mini-Circuits TIA-1000-1R8 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Mini-Circuits TIA-1000-1R8.
Be careful changing these setting as RadiMation® is no longer able to verify if the Mini-Circuits TIA-1000-1R8 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
