Narda 22612
Jump to: navigation, search
The Narda 22612 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda 22612:
The frequency range of the Narda 22612 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda 22612.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda 22612 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
