Narda 3020A
Jump to: navigation, search
The Narda 3020A device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda 3020A:
The frequency range of the Narda 3020A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda 3020A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda 3020A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
