Narda 3042B-20
Jump to: navigation, search
The Narda 3042B-20 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda 3042B-20:
The frequency range of the Narda 3042B-20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda 3042B-20.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda 3042B-20 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
