Narda EMC-300
The Narda EMC-300 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda EMC-300:
The frequency range of the Narda EMC-300 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda EMC-300.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda EMC-300 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Narda EMC-300
- Google image search: Narda EMC-300
