Narda PMM 6630
The Narda PMM 6630 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda PMM 6630:
The frequency range of the Narda PMM 6630 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda PMM 6630.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda PMM 6630 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Narda PMM 6630
- Google image search: Narda PMM 6630
