Narda Type 18
The Narda Type 18 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Narda Type 18:
The frequency range of the Narda Type 18 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Narda Type 18.
Be careful changing these setting as RadiMation® is no longer able to verify if the Narda Type 18 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Narda Type 18
- Google image search: Narda Type 18
