Nucletudes 03.40.140A
Jump to: navigation, search
The Nucletudes 03.40.140A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Nucletudes 03.40.140A:
The frequency range of the Nucletudes 03.40.140A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Nucletudes 03.40.140A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Nucletudes 03.40.140A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
