Nucletudes 08.40.100A
The Nucletudes 08.40.100A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Nucletudes 08.40.100A:
The frequency range of the Nucletudes 08.40.100A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Nucletudes 08.40.100A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Nucletudes 08.40.100A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Nucletudes 08.40.100A
- Google image search: Nucletudes 08.40.100A
