Ophir RF 5085
The Ophir RF 5085 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 5085:
The frequency range of the Ophir RF 5085 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ophir RF 5085.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ophir RF 5085 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Ophir RF 5085
- Google image search: Ophir RF 5085
