Ophir RF 5265
The Ophir RF 5265 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 5265:
The frequency range of the Ophir RF 5265 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ophir RF 5265.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ophir RF 5265 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Ophir RF 5265
- Google image search: Ophir RF 5265
