Ophir RF 6536 TWT
The Ophir RF 6536 TWT device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 6536 TWT:
The frequency range of the Ophir RF 6536 TWT as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ophir RF 6536 TWT.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ophir RF 6536 TWT is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Ophir RF 6536 TWT
- Google image search: Ophir RF 6536 TWT
