PMM 7010 LISN
Jump to: navigation, search
The PMM 7010 LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM 7010 LISN:
The frequency range of the PMM 7010 LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM 7010 LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM 7010 LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
