PMM 9010
Jump to: navigation, search
The PMM 9010 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM 9010:
The frequency range of the PMM 9010 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM 9010.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM 9010 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
The PMM 9010 Spectrum analyser can be controlled over USB or GPIB. If the device is to be controlled over USB, the USB <=> Serial port drivers as provided by PMM has to be installed first.
This device driver allows that multiple traces are measured simultaneously. This is only possible in the PMM 9010 'Sweep' mode. In this 'Sweep' mode, it is however necessary to always use auto attenation. It is not possible to use a fixed attenuation. PMM responded with:
We confirm that command “SSFD” doesn’t affect Attenuators’ settings, as we simply didn’t design it to be changed by remote control, which would have meant accessing up to 4 menus in Manual Mode. Therefore we’ll define forcing Attenuators’ settings in AUTO mode starting from the next FW release, as that’s the only mode we intend to support.
