PMM 9030 connected to 9010F
Jump to: navigation, search
The PMM 9030 connected to 9010F device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM 9030 connected to 9010F:
The frequency range of the PMM 9030 connected to 9010F as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM 9030 connected to 9010F.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM 9030 connected to 9010F is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
