PMM DR-01
The PMM DR-01 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM DR-01:
The frequency range of the PMM DR-01 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM DR-01.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM DR-01 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
