PMM L1-150
Jump to: navigation, search
The PMM L1-150 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM L1-150:
The frequency range of the PMM L1-150 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM L1-150.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM L1-150 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
