PMM LP-04
The PMM LP-04 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM LP-04:
The frequency range of the PMM LP-04 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the PMM LP-04.
Be careful changing these setting as RadiMation® is no longer able to verify if the PMM LP-04 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
