Prana AP32DR216 RF Coupler
Jump to: navigation, search
The Prana AP32DR216 RF Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana AP32DR216 RF Coupler:
The frequency range of the Prana AP32DR216 RF Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana AP32DR216 RF Coupler.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana AP32DR216 RF Coupler is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
