Prana AP32MT210
Jump to: navigation, search
The Prana AP32MT210 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana AP32MT210:
The frequency range of the Prana AP32MT210 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana AP32MT210.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana AP32MT210 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
