Prana AP32SV107A
Jump to: navigation, search
The Prana AP32SV107A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana AP32SV107A:
The frequency range of the Prana AP32SV107A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana AP32SV107A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana AP32SV107A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
