Prana DT 25-25
Jump to: navigation, search
The Prana DT 25-25 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana DT 25-25:
The frequency range of the Prana DT 25-25 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana DT 25-25.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana DT 25-25 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
