Prana MT 500DC
Jump to: navigation, search
The Prana MT 500DC device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana MT 500DC:
The frequency range of the Prana MT 500DC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana MT 500DC.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana MT 500DC is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
