Prana N-MT 1650D
The Prana N-MT 1650D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana N-MT 1650D:
The frequency range of the Prana N-MT 1650D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Prana N-MT 1650D.
Be careful changing these setting as RadiMation® is no longer able to verify if the Prana N-MT 1650D is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Prana N-MT 1650D
- Google image search: Prana N-MT 1650D
