R+B Inc. ICN-107
Jump to: navigation, search
The R+B Inc. ICN-107 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the R+B Inc. ICN-107:
The frequency range of the R+B Inc. ICN-107 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the R+B Inc. ICN-107.
Be careful changing these setting as RadiMation® is no longer able to verify if the R+B Inc. ICN-107 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
