RadiMation Error: 536879971
The correction file ('<correction filename>'), does not contain any column.
During the loading of the specified correction file, it is checked if columns are present in the correction file. This error is raised if it is detected that the correction file does not contain any column at all.
Solution
- Correct the contents of the correction file, by adding the correct columns.
- The 'Correction file uses' section of Chapter 14 of the manual contains a description of the expected content of the correction file.
