Raditeq GTM0500A
The Raditeq GTM0500A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq GTM0500A:
The frequency range of the Raditeq GTM0500A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Raditeq GTM0500A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Raditeq GTM0500A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Raditeq GTM0500A
- Google image search: Raditeq GTM0500A
