Raditeq RSS2010H
Jump to: navigation, search
The Raditeq RSS2010H device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RSS2010H:
ScreenElementDescription.png Measure The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
ScreenElementDescription.png Max. Difference If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
The frequency range of the Raditeq RSS2010H as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Raditeq RSS2010H.
Be careful changing these setting as RadiMation® is no longer able to verify if the Raditeq RSS2010H is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
There are several methods in which the Raditeq RSS2010H can be connected to the PC. The Raditeq RSS2010H can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the Raditeq RSS2010H is connected.
When the Raditeq RSS2010H is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
ScreenElementDescription.png Directly to PC Specifies that the Raditeq RSS2010H is connected directly to the PC, without the use of a RadiCentre.
ScreenElementDescription.png RadiCentre 1 Specifies that the Raditeq RSS2010H is connected to a plugincard that is fitted in a RadiCentre 1.
ScreenElementDescription.png RadiCentre multi-slot Specifies that the Raditeq RSS2010H is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
ScreenElementDescription.png RadiCentre multi-slot Ultra Specifies that the Raditeq RSS2010H is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the Raditeq RSS2010H itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the Raditeq RSS2010H is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the Raditeq RSS2010H:
  • RadiCentre tab
  • Communication tab
    • Communication Stream: VISA
    • LAN: 192.168.178.95
The Software update tab can be used to update the software of the Raditeq RSS2010H.
Warning: The software update can take a few minutes. During the actual software update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the Raditeq RSS2010H and the PC, while the software update is being performed.
The RadiSense tab can be used to configure the specific settings of the Raditeq RSS2010H.
ScreenElementDescription.png Direction If the field strength of a specific single axis or an isotropic value should be measured.
ScreenElementDescription.png Filter Setting The filter that should be used during the measurements.
The User Calibration tab can be used to upload the data of an user calibration into the Raditeq RSS2010H. This calibration data can be used by the probe internally to to correct the measured values.
ScreenElementDescription.png Use calibration correction if available If this option is activated, and if a user calibration is stored in the probe, then the correction will be used by the probe itself, to internally correct the measured value with the user calibration data. If this option is off, no correction of the measured values will be done.
ScreenElementDescription.png Browse Allows to select the correction file that contains the User Calibration data of the Raditeq RSS2010H.
ScreenElementDescription.png Program calibration table Starts the actual uploading of the calibration table. First some checks are performed, and if those checks are successful, the actual uploading is performed.
For more information on how to program the RadiSense 10 calibration table, see https://wiki.radimation.com/wiki/index.php/RadiMation_Application_Note_135
