Raditeq RSW1062Q
The Raditeq RSW1062Q device driver is a Switch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RSW1062Q:
There are several methods in which the Raditeq RSW1062Q can be connected to the PC. The Raditeq RSW1062Q can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the Raditeq RSW1062Q is connected.
When the Raditeq RSW1062Q is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC | Specifies that the Raditeq RSW1062Q is connected directly to the PC, without the use of a RadiCentre. |
RadiCentre 1 | Specifies that the Raditeq RSW1062Q is connected to a plugincard that is fitted in a RadiCentre 1. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the Raditeq RSW1062Q itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the Raditeq RSW1062Q is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the Raditeq RSW1062Q:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Software update tab can be used to update the software of the Raditeq RSW1062Q.
During and After |
