Raditeq RadiField adjustment generator
Jump to: navigation, search
The Raditeq RadiField adjustment generator device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Raditeq RadiField adjustment generator:
The frequency range of the Raditeq RadiField adjustment generator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Raditeq RadiField adjustment generator.
Be careful changing these setting as RadiMation® is no longer able to verify if the Raditeq RadiField adjustment generator is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
