Rigol Technologies DSG 815
The Rigol Technologies DSG 815 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rigol Technologies DSG 815:
The frequency range of the Rigol Technologies DSG 815 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rigol Technologies DSG 815.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rigol Technologies DSG 815 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rigol Technologies DSG 815
- Google image search: Rigol Technologies DSG 815
