Rigol Technologies RSA 3030N
The Rigol Technologies RSA 3030N device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rigol Technologies RSA 3030N:
The frequency range of the Rigol Technologies RSA 3030N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rigol Technologies RSA 3030N.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rigol Technologies RSA 3030N is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Rigol Technologies RSA 3030N
- Google image search: Rigol Technologies RSA 3030N
