Rigol Technologies RSA 3045N
Jump to: navigation, search
The Rigol Technologies RSA 3045N device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rigol Technologies RSA 3045N:
The frequency range of the Rigol Technologies RSA 3045N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rigol Technologies RSA 3045N.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rigol Technologies RSA 3045N is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
