Rohde & Schwarz ENV4200 RadIO Controlled LISN
Jump to: navigation, search
The Rohde & Schwarz ENV4200 RadIO Controlled LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ENV4200 RadIO Controlled LISN:
The frequency range of the Rohde & Schwarz ENV4200 RadIO Controlled LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ENV4200 RadIO Controlled LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ENV4200 RadIO Controlled LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
